It is currently Sat Sep 13, 2025 4:07 pm
 Post subject: Steps in making pegs
PostPosted: Wed Nov 20, 2024 9:31 am
First name: Ken
Last Name: Nagy
City: Goodrich
I just made some pegs. I have 2 that still don't have the head carved down yet.
The first step is the rough turning.
Then I change jaws, and turn the head to the approximate shape. At this point the button is done, because it had the taper, and the groove for the tail gut cut, on the first side.I just round out the other side,
Then I cut the taper, and carve in the shoulder. It will need shimming to get it true again. If it isn't perfect, no one will know that the head is .002" off. I use the cutting tool to mark the 2 grooves. I cut with files. Then I polish it all up.
Now the head needs to be carved down. You could use the round end of a belt sander. It is concave north/south, and convex east/west. I used a knife. It worked great. Not much dust.
I smoothed it up by scraping. The shape is by feel. The edges should all be about the same, to about the widest point. It should look even.
Then it needs the carving that makes it look like a heart. I start with an X-acto cut for the centerline; then carve away with a 6mm chisel. I could use a 3mm chisel.
This is a shot showing the shape:
I finish with CA pore fill. I brush some iron acetate in the area between the collar and the head, to darken it so it recedes out of view. Polished with micromesh. This is almost complete filling; better than it was. I'll leave it like that so it looks like wood. They feel nice.
Why be normal?
These users thanked the author Ken Nagy for the post (total 5): kyle.medeiros (Thu Nov 21, 2024 12:36 am) • Dave Rickard (Wed Nov 20, 2024 4:41 pm) • SteveSmith (Wed Nov 20, 2024 12:56 pm) • Craig Wilson (Wed Nov 20, 2024 10:26 am) • bcombs510 (Wed Nov 20, 2024 9:55 am)
 Post subject: Re: Steps in making pegs
PostPosted: Wed Nov 20, 2024 11:12 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Beautiful. Thank you for the tutorial.
PostPosted: Wed Nov 20, 2024 3:46 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Those are beautiful, Ken. So much attention to detail in a small part that probably makes a big impression on the player.
PostPosted: Wed Nov 20, 2024 4:41 pm
City: Lawrence
Zip/Postal Code: 66047
Way cool Ken. Thanks for the tutorial.
PostPosted: Wed Nov 20, 2024 7:09 pm
Lovely, really nice work.
PostPosted: Fri Nov 22, 2024 8:06 pm
Great tutorial Ken. I've been thinking about making a flamenco with pegs instead of machine turners.
PostPosted: Sat Nov 23, 2024 9:14 am
First name: Ken
Last Name: Nagy
City: Goodrich
Brent,
I'm finishing up some pegs I made for a small Torres. The original had pegs. I think I used the cream colored part of a board labeled "Royal Ebony." I think it is Katalux. But it could be something different. Pegs don't have to be real hard; they can wear out the hole then; if they aren't really smooth, and have some lube. Walnut, cherry, maple, can all be used. Often I match the pegs and the fingerboard. The fretboard on the Torres is a purplish Katalux. Something interesting is nice if you are going to the trouble to make them.
On these, the stock was narrow, a little over 3/4" I like them wider. The one think I don't like about what I did is the undercut is too wide. I think I was having trouble with he knife slipping and nipping the collar. It wasn't a good idea. What was a good idea, is the way I didn't the last ones. Cut a line down the middle with a knife, and whittle away at the curve with a sharp chisel. Twist the chisel to smooth the bottom up. Even my 6 mm chisel didn't mar up the collar.
It looks like I made the 1/8" rounded chisel for the u'cut out of the shank of an old 5/16" HSS end mill!
Why be normal?
cron
